CSV Import
CSV Import
how can I integrate the newly created fields into my inport?
best regards
best regards
- Screen Shot 2016-12-01 at 14.36.20.png (109.28 KiB) Viewed 1814 times
Re: CSV Import
Can you please add more details what you would like to achieve? It's not clear from your screenshot and description.
Re: CSV Import
Sorry,
thats my code, i try to import my own types inside see printscreen of my first contribution:
controller.common.product.import.csv.separator = ,
container.type = Directory
location = /var/www/vhosts/demo.de/httpdocs/typo3temp/aimeos/
mapping {
item {
0 = product.code
1= product.label
2 = product.type
3 = product.status
text {
4 = text.languageid
5 = text.type
6 = text.content
7 = product.text.languageid
8 = product.text.type
9 = product.text.content
catalog {
10 = catalog.code
Re: CSV Import
If you want to use more text types, you have to add them in the admin interface first and than you can use the codes in your CSV file. Is that what you've meant?
