New first level category
I want to create a new first level category. But it's not possible. Or not?
- 2016-12-05.jpg (18.52 KiB) Viewed 1809 times
Re: New first level category
Categories are a tree structure and can only have one root node.
But you can add as many categories below the root node and configure them as starting points for e.g. the catalog filter.
is it possible to start showing from level 1 ?
example:
- root
-- cat1
-- cat2
-- cat 3
--- cat3.1
--- cat3.2
I dont want to show root on my site .
example:
- root
-- cat1
-- cat2
-- cat 3
--- cat3.1
--- cat3.2
Simply hide the root node in the frontend via CSS if you don't want to show it.
