Email sending cron job fails
When the cron job to send emails is executed manually we get the error:
Execution of task "Aimeos Shop e-mail scheduler (aimeos)" failed with the following message: Address in mailbox given [] does not comply with RFC 2822, 3.6.2.
The Typoscript configuration for the cron job includes:
plugin.tx_aimeos.settings.client.html.email.bcc-email = MyEmail@MySite.com
TYPO3 CMS 6.2.17
aimeos 16.4.3
Linux
PHP version: 5.6.27
Any suggestions on debugging this?
Thank you -- Tony
TYPO3 CMS 6.2.17
aimeos 16.4.3
Linux
PHP version: 5.6.27
Thank you -- Tony
Re: Email sending cron job fails
Have a look at your orders. Seems that at least one has no e-mail address in the mshop_order_base_address table.
I looked in the mshop_order_base_address table, and found several older orders without email addresses. I added email addresses to those orders in that table.
I still got the error when trying to run the scheduler event. I then reduced the email types included in the cron job, and found that it was the Customer account emails that caused the failure.
Would those be in a different table?
Thank you -- Tony
Thank you -- Tony
They are offloaded to a queue and you can find the queue entries in the madmin_queue table.
The queue entries are removed as soon as they are processed, so you still may accept customer addresses without e-mail addresses in the checkout process.
