Sorting of property
derJu
Sorting of property
Post by derJu » 03 Jan 2017, 10:18
hi,
how can i sort the property's?
plugin.tx_aimeos.settings.client.html.catalog.detail.additional.property.standard {
  0 = property-01
  1 =  property-02
  2 = property-03
best regards
derju
Re: Sorting of property
Post by aimeos » 03 Jan 2017, 15:05
There's currently no sorting from the database:
https://github.com/aimeos/ai-client-htm ... d.php#L272
You should copy the template and sort the property items as you need them before generating the HTML:
https://github.com/aimeos/ai-client-htm ... efault.php
derJu
Post by derJu » 18 Jul 2017, 17:29
The properties in the details page are not reflected in the live order as in the backed. This is only after the upgrade to the latest version 2017.07. How can i adjust this?
best regards
Post by aimeos » 19 Jul 2017, 10:19
Sorting the product properties is done in the template and it depends if your template does the same:
https://github.com/aimeos/ai-client-htm ... lt.php#L83
derJu
Post by derJu » 19 Jul 2017, 10:38
Thank you for the reference!
