Add the number of products in the shopping cart.
Hi.
My cms typo3 7.6.15, aimeos 16.10.3, bootstrap pack 6.2.16
I have a problem when you add the number of items in the cart.
Console writes error - "Failed to load resource: net::ERR_NAME_NOT_RESOLVED http://%7B%24tx_aimeos.basket.target%7D/"
This happens when you press the "+", "-" or any other button.
Pls help me.
Pls help me.
Re: Add the number of products in the shopping cart.
The constant for the basket page ID isn't set. You should add this to the "constants" section of your TypoScript configuration:
tx_aimeos.basket.target = <basket page uid>
Thank you. Everything is working.aimeos wrote:The constant for the basket page ID isn't set. You should add this to the "constants" section of your TypoScript configuration:Code: Select all
