Catalog parent child relation
Let's say I follow these steps
- Create parent catalog
- Create child catalog
- Assign one product to child catalog
When I am in the child catalog, the product shows up.
However when I am in the parent catalog, the product does not show up.
It only shows up if I assign the product to both catalogs.
I thought the parents will contain all their child catalog products. Am I doing something wrong ?
Re: Catalog parent child relation
What you describe is the normal behavior. You can change that using the https://aimeos.org/docs/Configuration/C ... sts/levels configuration to show products in parent categories too.
