Extend Omnipay
Extend Omnipay
I'm doing my integration service payment test. I do not have Compose on my current server.
I found https://github.com/ck-developer/omnipay-payline to have a Payline gateway for Omnipay.
As this one is not integrated in Aimeos_pay extension, I think that create a new Typo3 extension is the best way.
Because otherwise an update of the extension "Aimeos_pay" will delete my library.
So I have :
A Typo3 extension with my Payline class :
/typo3conf/ext/kaloa_aimeos_payline/Resources/Private/Extensions/kaloa_aimeos_payline/lib/custom/src/MShop/Service/Provider/Payment/Payline.php
In the backend, I configure my new payment Service with provider value to "Payline".
It's Ok... The class is found and I move on to the "Resume" step.
I click on the "Buy" button and there I get the error "Class '\Omnipay\Payline\WebGateway' not found".
Logic, Omnipay does not know this.
I try to simply create a Libraries directory in the Private folder "/typo3conf/ext/kaloa_aimeos_payline/Resources/Libraries/ck-developer/omnipay-payline" in which I filed the folder "ck-developer" but after ... ???
How to declare this new library to Omnipay ?
Thank you
By the way, I've change : 'aimeos' => '16.3.0-16.99.99', to 'aimeos' => '16.3.0-17.99.99' to be compatible in aimeos_pay/ext_emconf.php
So I have :
namespace Aimeos\MShop\Service\Provider\Payment;
class Payline
extends \Aimeos\MShop\Service\Provider\Payment\OmniPay
implements \Aimeos\MShop\Service\Provider\Payment\Iface
* Returns the prefix for the configuration definitions
* @return string Prefix without dot
protected function getConfigPrefix()
return 'Payline';
* Returns the value for the given configuration key
* @param string $key Configuration key name
* @param mixed $default Default value if no configuration is found
* @return mixed Configuration value
protected function getValue( $key, $default = null )
switch( $key )
case 'type': return 'Payline\Web';
case 'onsite': return false;
return parent::getValue( $key, $default );
}It's Ok... The class is found and I move on to the "Resume" step.
Thank you
Re: Extend Omnipay
I reply to myself:
In ext_localconf.php of the extension foreach file:
Require_once \ TYPO3 \ CMS \ Core \ Utility \ ExtensionManagementUtility :: extPath ($ _EXTKEY). '/Resources/Libraries/ck-developer/omnipay-payline/src/AbstractGateway.php';
