new template to "address-body-default"
Hey.
My cms typo3 7.6.15, aimeos 16.10.3, bootstrap pack 6.2.16
How can I specify the path to the new template for "/common/summary/address-body-default.php" ?
Information in the manual is not found, there is information only for older versions of the store.
I tried a lot of customization options, by selection, but I did not succeed. Tell me what went wrong. ?
plugin.tx_aimeos.settings.client.html.common.summary.address.template-body = template/shop/common/summary/address-body-default.php
Re: new template to "address-body-default"
The configuration for the address template in order summaries of the 2016.x versions depends on the component:
- https://github.com/aimeos/ai-client-htm ... d.php#L102
- https://github.com/aimeos/ai-client-htm ... rd.php#L99
- https://github.com/aimeos/ai-client-htm ... d.php#L101
