Invalid locale ""
Invalid locale ""
It is impossible to start aimeos module in Typo3 backend after updating to Typo3 7.6.16.
It displays "Uncaught TYPO3 Exception" when you attempt to switch Expert mode.
Error Log:
Core: Exception handler (WEB): Uncaught TYPO3 Exception: Invalid locale "" | Aimeos\MW\Translation\Exception thrown in file /-----/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mwlib/src/MW/Translation/Base.php in line 34. Requested URL: http://www.elementel.com/typo3/index.ph ... 5Blang%5D=
I am not familiar with php errors. Maybe you can help.
Error Log:
Re: Invalid locale ""
None of the admin interfaces work any more due to this change in TYPO3 7.6.16:
You can install this package which contains a workaround for the TYPO3 change:
https://aimeos.org/fileadmin/download/a ... 0-pre5.zip
2017-02-16 4a92123 #79835 [BUGFIX] UriBuilder: Do not skip empty parameters (Markus Klein)
Thank you. Working.
when will the fix be available for 16.10.x?
Thanks for helping.
Thanks for helping.
The workaround is already in the 2016.10 branch and if you use composer, available when using
We plan a minor 16.10.4 release in TER beginning of next week.
"aimeos/aimeos-typo3": "2016.10.x-dev"
