Action buttons in list view
Can we add the action button features like Add to cart, pin, watch, wishlist in product list page?? I saw that it can be implemented in detail view. Is it possible with list view?? See the attachment for reference.
- cart.png (133.7 KiB) Viewed 4147 times
Re: Action buttons in list view
Yes, you can simply copy the code from the detail template to the list template:
https://github.com/aimeos/ai-client-htm ... efault.php
We simplified that a bit further and replaced the actions subpart with a partial just like for the social media links:
- https://github.com/aimeos/ai-client-htm ... t.php#L261
- https://github.com/aimeos/ai-client-htm ... efault.php
This will be part of the next release in April.
Thank you.. Itz working.
is this still valid for version 2019.10? - unfortunately I didn't get it to work
I'd like to add the watch- and favorite list buttons on our catalog list.
Thank's
Thank's
Yes, only the file names changed:
- https://github.com/aimeos/ai-client-htm ... andard.php
- https://github.com/aimeos/ai-client-htm ... #L310-L328
I am receiving a non-recoverable error when copying that partial to my list template. Could someone share the exact code they used in their list template to add the product actions?
Make sure your use the templates that correspond you to your Aimeos version, e.g. for 2019.10:
Thanks for the super fast reply!
I am using the aimeos typo3 extension and had to uncomment the for each loop the product listing items is wrapped in and change $this->productItem-> to $productItem-> and now it seems to be working
