I would like to add product programmability to the catalog
I would like to add product programmability to the catalog in my store. However, I have vendor directory under .git_ignore , what is the best practice to extend aimeos for my application without saving my application code under vendor?
Re: I would like to add product programmability to the catal
Please create your own product specific Aimeos extension for all your code, templates and modifications:
https://aimeos.org/docs/Developers/Create_an_extension
We have gone through the documentation; it seems we can only add extensions under vendor/src/ext directory.
However, in all our projects vendor is usually ignored by git. Can we specify a different directory for ext inside our app directory? we use laravel 5.3
The standard extension directory in Laravel for Aimeos is "./ext/" (in your application directory alongside with ./public/, ./app/, etc.)
