How to get the basket items with properties in other class
Starringstars
Post by Starringstars » 16 May 2017, 16:58
How can I get the basket items with all their properties in another class. Separated from the vendor Laravel dir.
Not the frontend generated code but the php functions which are private or protected. Ore is there an abstract class which I can insert? :geek:
I know how to get the forntend with:
$params = app( '\Aimeos\Shop\Base\Page' )->getSections( 'basket-index' );
print_r ($params);
But need the backend ass well in php functions.
Thank you!
Re: How to get the basket items with properties in other cl
Post by aimeos » 17 May 2017, 19:16
Did you read this article?
https://aimeos.org/docs/Laravel/Extend_Aimeos
With the context object you can instantiate the basket controller and get the basket content:
https://github.com/aimeos/ai-controller ... end/Basket
Starringstars
Post by Starringstars » 25 May 2017, 03:13
Yes... Merci I've found the methods! :D
Sergunik
Post by Sergunik » 15 May 2018, 08:15
It's still issue for me.
Dear Support, Could you please help get basket items in own controller?
PHP 7.0.22-0ubuntu0.16.04.1
laravel/framework: 5.5
aimeos/ai-laravel: 2018.04.1
Sergunik
Post by Sergunik » 15 May 2018, 09:34
Found solution:
<?php
namespace App\Helper;
class BasketHelper extends BaseHelper
     * @return \Aimeos\Controller\Frontend\Basket\Standard
     * @throws \Aimeos\Controller\Frontend\Exception
     * @throws \Illuminate\Container\EntryNotFoundException
    private static function getBasketController()
        return \Aimeos\Controller\Frontend\Factory::createController( self::getContext(), 'basket' );
     * @return \Aimeos\MShop\Order\Item\Base\Product\Standard[]
    public static function getProducts() {
        $controller = self::getBasketController();
        $summaryBasket = $controller->get();
        return $summaryBasket->getProducts();
DiegoFelipeProaño
Post by DiegoFelipeProaño » 27 Aug 2018, 05:09
@Sergunik
How does your BaseHelper Class look like?
Sergunik
Post by Sergunik » 22 Oct 2018, 13:01
DiegoFelipeProaño wrote:How does your BaseHelper Class look like?
<?php
class BaseHelper
     * @return \Aimeos\MShop\Context\Item\Standard $context
    protected static function getContext() {
        return app('\Aimeos\Shop\Base\Context')->get();
