AIMEOS PACKAGE IN CUSTOM DIRECTORY INSTEAD OF VENDORS
I would like to install aimeos in a custom directory rather than in the vendors while using the composer.
How should I go about it?
Am using Laravel 5.2, aimeos ~2016.10 on Linux environment.
Thanks.
Thanks.
Re: AIMEOS PACKAGE IN CUSTOM DIRECTORY INSTEAD OF VENDORS
You can change the directory composer is using in your composer.json but separating the Laravel packages from the rest of the packages in ./vendor/ only works with custom installers. The package type used by Aimeos is "laravel-bundle".
For more details please refer to https://getcomposer.org/doc/articles/cu ... tallers.md
