some changes in my own aimeos extension are not applied
Hi
So i created my own aimeos extension via the generator:
https://aimeos.org/developer/extensions/
However it only applies some of the template changes that i've made in the extension. For example:
In the directory catalog/lists/ i added a simple test div in the file body-default.php and it worked. However I did the same in the file items-body-list.php and that didn't work.
I've cleared the cache via the install tool, the aimeos scheduler as well as the browser cache. I don't get why it's not working.
Any ideas?
Linux, PHP 7.0.11, TYPO3 7.6.18/8.7.1
Any ideas?
Re: some changes in my own aimeos extension are not applied
Tested this again and it works as expected.
Please notice that "items-body-list.php" is the ALTERNATIVE list view when you click on the rightmost icon right of the pagination/sorting section. The standard list view is "items-body-default.php". If you haven't deactivated the Aimeos content cache in the extension manager, you have to clear the TYPO3 frontend cache after any change.
