Changing Tax rate base on US states
Hi
How do I change the tax rate base on US States ,
like for example
Ca >> 9.8%
can you do that? please guide me through it
Also I want to remove the Rebate from checkout, how do we do that
like for example
Ca >> 9.8%
Re: Changing Tax rate base on US states
The Aimeos company has an extension for applying tax rates to products based on countries/states:bill wrote: How do I change the tax rate base on US States , like for example
Ca >> 9.8%
https://aimeos.com/extensions/
Overwrite the basket template and remove the HTML code from the templatebill wrote: Also I want to remove the Rebate from checkout, how do we do that
Thanks for your help
