Stripe Payment gateway not working
HI
I have installed stripe and followed instruction and I did composer update , and in Aimeo admin I added this as follows: ( see screen shot)
when I check out and click on "buy now" it takes me to enter credit card info WHICH seems to be working fine, so I put the following info for testing .
Now when I click on "Pay Now" I get this :
and when I click on proceed , its stuck doesn't do anything?? do you know what is going on with it anything wrong with my settings
- screen-admin.png (84.64 KiB) Viewed 4325 times
- Last - step-proceed.png (36.01 KiB) Viewed 4340 times
- next - step -enter crediot card.png (64.69 KiB) Viewed 4340 times
Re: Stripe Payment gateway not working
Hi
I am using this :
"aimeos/aimeos-laravel": "~2017.04",
Here is my composer.json
I am using this :
"require": {
"php": ">=5.6.4",
"barryvdh/laravel-debugbar": "^2.3",
"laracasts/utilities": "^2.1",
"laravel/framework": "5.4.*",
"laravelcollective/html": "^5.3.0",
"solarium/solarium": "^3.8",
"mpociot/couchbase": "^0.2.0",
"aimeos/ai-payments": "~2017.04",
"omnipay/stripe": "~2.0"
"require-dev": {
"fzaninotto/faker": "~1.4",
"mockery/mockery": "0.9.*",
"phpunit/phpunit": "~5.7",
"symfony/css-selector": "3.1.*",
"symfony/dom-crawler": "3.1.*"
Also is it suppose after you fill the credit card info to show you the Proceed button?? it just doesn't make sense to me
I remember there was a pull request on GitHub fixing this issue.
Can you please try dev-master instead of 2017.04?
So you mean update composer like this
"aimeos/aimeos-laravel": "dev-master",
"aimeos/ai-payments": "dev-master",
Yes. Please run "./artisan aimeos:setup" afterwards so the database schema is automatically updated.
it worked now after the update , I see the payment in Stripe
Can I use it with Apple Pay , or that is a separate integration?
