Aimeos Pay - Omnipay does not work
Hi aimeos,
Omnipay does not work after update to the latest version of Aimeos.
I got a Error when i came back to the confirm in aimeos:
You have an idea how to fix this problem?Invalid response from payment gateway
- Screen Shot 2017-06-13 at 15.54.50.png (120.62 KiB) Viewed 2926 times
Re: Aimeos Pay - Omnipay does not work
Which versions do you exactly use and most important, which Omnipay payment driver?
Hi Aimeos,
I use the Omnipay payment driver Postfinance:
https://github.com/bummzack/omnipay-postfinance
TYPO3 8.7.1
Aimeos 17.4.1
Aimeos_Pay 16.10.0
TYPO3 8.7.1
Aimeos 17.4.1
Aimeos_Pay 16.10.0
Does this also happen with the latest aimeos_pay version (17.6.0)?
It does not change anything! The same error in aimeos_pay 17.06.0.
I have found out that the orderid is not attached to the following values.
in the old version with aimeos 16 it looks like
Where are the set?
<input type="hidden" name="ACCEPTURL" value="https://www.doami.de/shop/confirm/cc/postfinance/"/>
<input type="hidden" name="CANCELURL" value="https://www.doami.de/shop/confirm/cc/postfinance/"/>
<input type="hidden" name="ACCEPTURL" value="https://www.domain.de/shop/confirm/cc/postfinance/215/"/>
<input type="hidden" name="CANCELURL" value="https://www.domain.de/shop/confirm/cc/postfinance/215/"/>
The order ID isn't necessary and can't be trusted so it was removed. But the removed order ID in the URL shouldn't be the source of the problem.
The message is created by the Omnipay/Postfinance driver:
https://github.com/bummzack/omnipay-pos ... st.php#L97
i think the orderid is necessary, in the vardump of $signData is the orderid empty:
https://github.com/bummzack/omnipay-postfinance/blob/master/src/Message/CompletePurchaseRequest.php#L87
"3021[/url]417812" ["STATUS"]=> string(1) "5" } array(4) { ["NCERROR"]=> string(1) "0" ["ORDERID"]=> string(0) "" ["PAYID"]=> string(10) "3021417812" ["STATUS"]=> string(1) "5" } array(4) { ["NCERROR"]=> string(1) "0" ["ORDERID"]=> string(0) "" ["PAYID"]=> string(10) "3021417812" ["STATUS"]=> string(1) "5" } array(4) { ["NCERROR"]=> string(1) "0" ["ORDERID"]=> string(0) "" ["PAYID"]=> string(10) "3021417812" ["STATUS"]=> string(1) "5" } array(4) { ["NCERROR"]=> string(1) "0" ["ORDERID"]=> string(0) "" ["PAYID"]=> string(10) "3021417812" ["STATUS"]=> string(1) "5" }
The ORDERID parameter is one that is sent as POST payload FROM the payment gateway and it only has the same name as the previously used Aimeos URL parameter:
https://github.com/bummzack/omnipay-pos ... st.php#L59
If it's an empty string, it might be a problem that it's not sent within the original POST request TO the payment gateway, even if it should be passed correctly as "transactionId" to the Omnipay driver:
https://github.com/aimeoscom/ai-payment ... y.php#L616
Can you confirm that there's an empty ORDERID value passed to the driver?
https://github.com/bummzack/omnipay-pos ... st.php#L31
