js error in IE11
pixls
js error in IE11
Post by pixls » 24 Jul 2017, 13:16
Hi
I just found out the aimeos.js in aimeos/Resources/Public/Themes is causing a js error in IE11. Because of this the images in the list view and the filter dont work anymore.
The error seems to be caused by the following for loop:
for(entry of basket.included) { }
You can see the error here in the aimeos demo shop:
http://typo3.demo.aimeos.org/demo/
TYPO3 8.7.3, PHP 7, aimeos 17.7.0
Re: js error in IE11
Post by aimeos » 24 Jul 2017, 16:48
The "for of" loops are part of the ES6 standard and seem to be only supported since IE12 (Edge). The alternative would be a "for(i=0; i<basket.included.length;i++)" loop. Are you able to provide a tested patch for this? Thank you :-)
pixls
Post by pixls » 25 Jul 2017, 06:24
Thank you very much, this fixed the problem. Just tested in IE11.
