Pin Problem Typo3 7.6.20 and aimeos ext 17.x / 16.x
tenkraD
Post by tenkraD » 25 Jul 2017, 09:08
I installed the newest aimeos extension 17.7.0. on Typo3 7.6.20 and done the installation like documented on https://aimeos.org/docs/TYPO3#Installation
The installation (page import v.17 and demo data) looks ok but my problem is im not able to pin an article from demo data. Shouldnt pinning work without extra configuration? Am i missing something?
If i install the aimeos distribution(17v dosent work for typo3 v7.6.x so i install the 16.10) pining works.
So I thought it could be because i have to install the aimeos extension v.16.10.5 on Typo3 7.6.20 (page import v.16) but now i got the same result, im not able to pin an article from demo data.
I need help, i dont know what im doing wrong.
My 2. question is do i really need the bootstrap distribution? I made my own based on twitter bootstrap and on https://aimeos.org/docs/TYPO3/Install_A ... requisites on requiered software nothing is written about that.
Many Thanks
tenkraD
Re: Pin Problem Typo3 7.6.20 and aimeos ext 17.x / 16.x
Post by aimeos » 25 Jul 2017, 17:09
Did you place the "Catalog Session" plugin on the same page as the "Catalog Detail" plugin? If not, please check the page reference to the page with the "Catalog Session" plugin in the flexform of the "Catalog Detail" plugin.
tenkraD
Post by tenkraD » 26 Jul 2017, 08:02
If u mean the plugin "catalog user related session" then yes i did.
and now i see this failure exist also on ure demo site.
http://typo3.demo.aimeos.org/demo/detai ... article/0/
tenkraD
Post by tenkraD » 26 Jul 2017, 08:09
could it be because the action parameter has changed? its now more action = add its now action = detail
tenkraD
Post by tenkraD » 26 Jul 2017, 10:09
i see its fixed on http://typo3.demo.aimeos.org/
The pin has now an working href, what was the problem?
How can i get the fix?
Many Thanks
Post by aimeos » 26 Jul 2017, 10:15
The page reference must be now explicitly set to the same page in the catalog detail plugin so the passed parameters are use. Seems like this changed in TYPO3 7.6.16 which made an incompatible change in parameter handling.
We will update the page tree file. Thank you for the hint! :-)
tenkraD
Post by tenkraD » 26 Jul 2017, 11:21
Thank u for the solution. Its working, yehaa.
