how to change seperatorDecimal & seperator1000
tenkraD
Post by tenkraD » 02 Aug 2017, 08:47
i would like to change seperator 1000 from empty space to '
and the seperator Decimal from . to ,
how can i do this?
[globalVar = GP:L = 1]
plugin.tx_aimeos.settings.client.html.common.format.seperatorDecimal = '
plugin.tx_aimeos.settings.client.html.common.format.seperator1000 = ,
[global]
[globalVar = GP:L = 2]
[global]
the above code is not working for me.
I am using aimeos 17.7.0 with typo3 7.6.20.
Metalics
Re: how to change seperatorDecimal & seperator1000
Post by Metalics » 02 Aug 2017, 11:47
You should correct the spelling mistake;
plugin.tx_aimeos.settings.client.html.common.format.separatorDecimal = '
plugin.tx_aimeos.settings.client.html.common.format.separator1000 = ,
tenkraD
Post by tenkraD » 02 Aug 2017, 11:55
Great thanks Metalics, that works!
pls update this in the documentation
https://aimeos.org/docs/TYPO3/Configure ... d_currency
Post by aimeos » 02 Aug 2017, 17:25
Documentation is updated. Thanks for the hint!
