shipping costs depending on basket weight
I have various delivery services with different weight configurations (Manual,Weight).
PostPacEconomy_2kg ( weight.min = 0.1 ,weight.max = 2 )
PostPacEconomy_5kg ( weight.min = 2.1 ,weight.max = 5 )
PostPacEconomy_10kg ( weight.min = 5.1 ,weight.max = 10 )
So the shipping costs depends on basket weight. In Aimeos 17.4.1 i had no problem when I changed the amount of an article in the basket. But after an update to 17.7.0 the shipping cost are no longer updated immediately on change only if i add a new article to the basket.
Should i do this differently now?
Regards Patrik
7.6.10, Aimeos 17.7.0 / PHP 5.6.30-0+deb8u1
Regards Patrik
Re: shipping costs depending on basket weight
Seems like the same issue as here:
help-f15/shipping-costs-disappear-from- ... t1058.html
Can you exchange the positions of the Autofill and ServicesUpdate basket plug-ins? (ServicesUpdate: 0, Autofill: 1)
I have exchanged the the positions but the problem still exists.
Can you post a screenshot of your plugin list and their configuration?
Here I have the service configuration:
and here is the plugin configuration:
The problem seems that editing products was done before by deleting and re-adding the product with the changed quantity in the basket. Now there's a specialized "editProducts()" method in the basket for this which sends its own new signal.
Can you please add this line
here for a quick test an see if it then works:
https://github.com/aimeos/aimeos-core/b ... te.php#L43
$p->addListener( $this->getObject(), 'editProduct.after' );
I've added the line, but still the same problem
here's the code:
here's the code:
Can you add it there as well:
https://github.com/aimeos/aimeos-core/b ... l.php#L156
It worked now!
I've added the 'editproduct.after()' function and maybe the cache didn't get the change.
thank you very much
thank you very much
Does only the ServicesUpdate plugin or also the Autofill plugin need to register for this event?
