Shipping costs disappear from basket
Re: Shipping costs disappear from basket
Post by aimeos » 28 Aug 2017, 15:04
Are you using the Aimeos TYPO3 16.10.5 release?
Post by aimeos » 31 Aug 2017, 21:33
Is the "Autofill" plugin still active and is its position after the ServicesUpdate plugin?
Post by aimeos » 01 Sep 2017, 08:57
The problem is most likely that this line was missing in the 2016.10 release up to now (it's already in the current 2017.07 version):
https://github.com/aimeos/aimeos-core/b ... ll.php#L33
Can you please add this line to your source code and test if it works now?
