Catalog node for ID "" not available - SOLVED!
Just installed Aimeos in a new Neos 3.2.0 installation and get this error on top of the search field:
What does it mean and what can i do to correct this?
I have added just one product and this shows up ok.
Regards,
Kim
Regards,
Kim
- aimeos_error.png (15.15 KiB) Viewed 2541 times
Neos 3.2.0 - Bitnami AWS C2 - Aimeos 2017-10.1
Re: Catalog node for ID "" not available
Looks like Neos is passing an empty parameter as default for the list route. Tried this with a plain Flow installation where this doesn't happen.
What is the URL in your address bar?
This is all that is in the addressbar:
http://(ip.address.hidden)/shop/list
Regards,
Kim
Regards,
Kim
Re: Catalog node for ID "" not available - SOLVED!
Think i solved this, but puzzled about the text in doc:
If users view a product list page without a category ID in the parameter list, the first found products are displayed with a random order. You can circumvent this by configuring a default category ID that should be used in this case (the ID of the root category is best for this). In most cases you can set this value via the administration interface of the shop application.
It seems it does not by default just use the first product without an error.
I then added the ID of the root category from the shop admin in Settings.yaml:
Error gone..
Aimeos:
Shop:
client:
html:
catalog:
lists:
catid-default: 1
