Custom content
Bfr
Custom content
Post by Bfr » 13 Oct 2017, 12:58
I want to add some custom content coming from the database. Is there any module or other way to display custom content? For example add in the footer a text that I can configure in the admin.
Thanks,
Bernard
Re: Custom content
Post by aimeos » 13 Oct 2017, 20:02
You can overwrite the Blade templates locally and add content there:
https://github.com/aimeos/aimeos-larave ... ws/catalog
Maybe you have to overwrite the controller classes, fetch your content from the database and change the routes to the new controller.
