Aimeos routes
Aimeos routes
Hi, I can't find aimeos routes.
Where are location of aimeos routes?
I'm using latest version of aimeos.
Thanks for help!
Thanks for help!
Re: Aimeos routes
They are there: https://github.com/aimeos/aimeos-larave ... routes.php
Re: Aimeos routes
So if I want to change product listing page name instead "list" to "products" how I could do that?
Re: Aimeos routes
Laravel allows you to overwrite routes in the routes/web.php file. Might be something like this:
But I'm not 100% sure. If this doesn't work, please ask in the Laravel forums for help.
Route::group(config('shop.routes.default', ['middleware' => ['web']]), function() {
Route::match( array( 'GET', 'POST' ), 'products', array(
'as' => 'aimeos_shop_list',
'uses' => 'Aimeos\Shop\Controller\CatalogController@listAction'
Re: Aimeos routes
I get "CatalogController does not exist" error, but thanks I will try to figure it out.
Re: Aimeos routes
I found a solution.
In config/app.php in the providers array put the service provider of the package before App\Providers\RouteServiceProvider::class, and then in your web.php routes you'll be able to override it with your custom route.
Also need to change route code and add slash.
Instead this:
Do this:
https://stackoverflow.com/questions/447 ... ckage?rq=1
Instead this:
'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction'
