Using Jobs in Neos
kimholberg
Using Jobs in Neos
Post by kimholberg » 28 Oct 2017, 16:05
I am trying to get Jobs working in Neos by using this manuel in command line instruction:
./flow aimeos:jobs "order/cleanup/unfinished"
but get this message:
bitnami@ip-172-31-73-205:/opt/bitnami/apps/neos/htdocs$ ./flow aimeos:jobs "order/cleanup/unfinished"
The URI must be a valid string.
Type: InvalidArgumentException
Code: 1176550571
File: Packages/Framework/Neos.Flow/Classes/Http/Uri.php
Line: 107
So what do i do wrong or miss. Aimeos manual is not very claer on this.
Neos 3.2.0 - Bitnami AWS C2 - Aimeos 2017-10.1
Re: Using Jobs in Neos
Post by aimeos » 29 Oct 2017, 13:00
Flow/Neos requires the baseUri configured when you execute Flow commands that may create URLs. Can you add this to your "Configuration/Settings.yaml" file:
Neos:
  Flow:
    http:
      baseUri: 'https://yourdomain.tld'
kimholberg
Post by kimholberg » 29 Oct 2017, 21:06
Thanks that solved the case and i could clean up unfinished orders.
One important point though:
you need the / at the end of the URI path, otherwise it won't work!
