Register/Login
Register/Login
Version 2017.10
I've noticed you did remove the register and login button from the main page.
Is there a particular reason why you did so?
Re: Register/Login
In the aimeos-laravel integration? Don't know if it was there any time before because authentication must be set up by you before this could work
Re: Register/Login
In the latest version of the Aimeos distribution, authentication is set up automatically and the site template contains the links for login/register as well as the selector for languages and currencies:
https://github.com/aimeos/aimeos
