How do I print an invoice
chricken
Post by chricken » 20 Nov 2017, 04:57
once again, there is a problem I can't solve by reading the doc or by websearch.
The shop owner wants to wants to sell by invoice, of course.
And I can not find the workflow, how to print an invoice to enclose it to the package.
Regards
Christian
PS: I need a workflow for the simple view, as the shop owner is not an expert.
Re: How do I print an invoice
Post by aimeos » 20 Nov 2017, 22:11
Aimeos doesn't care about invoicing because this is something for an accounting system. You can export the Aimeos orders in the order panel and the exported file will be available afterwards in the dashboard.
Alternatively, you can add a button that generates a PDF of the order if that is enough for your customer.
chricken
Post by chricken » 21 Nov 2017, 08:21
a printable PDF is enough.
Is there a ready to use implementation or do I have to make it myself?
Regards
Christian
Post by aimeos » 22 Nov 2017, 00:00
Haven't seen any generic solution for that because generating a PDF that can be adapted seems to be hard to implement
chricken
Post by chricken » 24 Nov 2017, 07:48
Okay,
I have been experimenting to generate a PDF from scratch on my own and I understand, that it is hard to do.
What I don't understand is, that shopping-software like Aimeos or tt-products, which I have used before, have such a hard time making a print-function for the invoices. That really annoys me.
Because the function to print an invoice seems very existential to me. A shop owner, who is selling by invoice (which is still payment #1 in germany), needs a simple way to get the invoice out of the software into the packet.
Do you have an alternative to print the invoice?
Maybe some BE-Plugin, thirdparty software or anything?
Regards
Christian
Post by aimeos » 24 Nov 2017, 20:53
chricken wrote: What I don't understand is, that shopping-software like Aimeos or tt-products, which I have used before, have such a hard time making a print-function for the invoices.
For Aimeos the answer is pretty simple: Aimeos isn't optimized for extremly small shops. Instead, the main target audience are shop owners who use at least accounting software, even if it's only something like Sage or Lexware (or their online counterparts) because invoicing is really their domain. On the other end, Aimeos will scale up to millions of products and ten-thousands of orders a day in highly complex setups with numerous integrations into other systems!
chricken wrote: Do you have an alternative to print the invoice?
We have good experience with the TCPDF library which abstracts low level stuff and makes generating PDFs a lot easier.
chricken
Post by chricken » 27 Nov 2017, 13:31
aimeos wrote: For Aimeos the answer is pretty simple: Aimeos isn't optimized for extremly small shops. Instead, the main target audience are shop owners who use at least accounting software, even if it's only something like Sage or Lexware (or their online counterparts) because invoicing is really their domain. On the other end, Aimeos will scale up to millions of products and ten-thousands of orders a day in highly complex setups with numerous integrations into other systems!
That's fine for me, I just wanted to know.
Right now, I am trying your suggestions (Sage and Lexware) and both are absolutely effordable for small businesses, too.
Regards
Christian
nos3
Post by nos3 » 27 Nov 2017, 13:51
We use the SageOne web service and are pretty satisfied: https://www.sageone.de/
chricken
Post by chricken » 27 Nov 2017, 13:57
nos3 wrote:We use the SageOne web service and are pretty satisfied: https://www.sageone.de/
Thank you for the hint :)
chricken
Post by chricken » 30 Nov 2017, 11:46
I guess, you have connected them via the Sage API, didn't you?
I can't find anything about it in the documentation. Can anyone please give me a hint, how to send information to Sage / Lexoffice?
Regards
Christian
