Free shipping
derJu
Free shipping
Post by derJu » 21 Nov 2017, 08:55
hello aimeos, is it possible to offer individual products free shipping? Without having to enter a discount code.
beste regards
derju
Re: Free shipping
Post by aimeos » 22 Nov 2017, 00:03
What does this mean? As long as all products in the basket are marked as "free shipping" no shipping costs are added just like for digital products? For downloads, there's a service decorator available (https://aimeos.org/docs/User_Manual/Adm ... s#Download) to show or hide one of two delivery options (with and without delivery costs)
derJu
Re: Free shipping
Post by derJu » 22 Nov 2017, 07:23
It means if a product is in the basket, such as "free shipping" the other products in the basket are also free to deliver.
best regards
jules
Re: Free shipping
Post by aimeos » 22 Nov 2017, 22:07
How should this "free shipping product" be added to the basket?
Stefan80
Re: Free shipping
Post by Stefan80 » 06 Sep 2019, 07:57
is it possible to set a single product to free shipping in the plugin "shipping" -"Free shipping above threshold"?
A special Product should have no shipping cost / skip the delivery process in the basket...
Re: Free shipping
Post by aimeos » 06 Sep 2019, 08:41
This does currently only work for products in a category if the "Category,Reduction" decorators are used. You can implement a product decorator that could do the same for the configured product codes.
Stefan80
Re: Free shipping
Post by Stefan80 » 16 Sep 2019, 09:26
Ok, thank you.
But can I create a delivery option (free shipping) and connect the Item to this option (so in the basket, "free shipping" is the only available option for this item)?
Re: Free shipping
Post by aimeos » 17 Sep 2019, 08:13
Yes, that should be possible:
- Add the "Required" decorator to your free shipping option and add the product code to the configuration on the right
- For all other shipping options, add "Not" and "Required" as decorator with the product code configured too
Example:
Free Shipping
Provider: Manual,Required
Config: required.productcode -> abcd
All other shipping options
Provider: Manual,Not,Required
