Passing multiple variables to view
Kevin
Post by Kevin » 28 Nov 2017, 20:02
Hi all,
I'm struggling with my Laravel + CodeIgniter instance. I did update my routes so the myaccount function is handled through my own controller instead of the default AccountController that comes with Aimeos.
The code to within my function is the following and works perfect:
$params = app( '\Aimeos\Shop\Base\Page' )->getSections( 'account-index' );
return Response::view('shop::account.index', $params);
Now I want to pass an extra parameter to the view, but the system keeps failing with everything I'm trying... I keep receiving the error that 'Aibody' in an undefined variable.
I did try every possible Laravel way to pass multiple parameters to the view:
return view('shop::account.subscriptions', compact('params', 'otherarray'));
$data = array(
		   'params'  => $params,
		   'testarray'   => $testarray,
return View::make('shop::account.subscriptions')->with($data);
Even this basic function to pass a variable to the view is failing:
return View::make('shop::account.subscriptions', compact('params'));
Who can help me out on this one? Much appreciated!
Regards,
Kevin
Re: Passing multiple variables to view
Post by aimeos » 28 Nov 2017, 22:29
What about simply using
$params['myparam'] = '...';
or
$params = array_merge( $params, $otherarray );
Kevin
Post by Kevin » 30 Nov 2017, 14:37
Thanks!
