decorators, delivery settings
Please be so kind to inform me how to setup delivery options with different price and countries
Example:
#1 Austria, Delivery POST, cost 8 EUR
#2 Germany, Delivery POST, cost 10 EUR
#3 USA etc, Delivery DHL, cost 29 EUR
Customer from Austria should only get the Option #1 (depending on his Austrian delivery address)
Problem is that the excludes and includes does not work and I always receive the wrong delivery option, only 1 or all together instead of 1 correct. Please be so kind to help me how to configure the decorator.
PHP Version: 7.0
Aimeos Version: aimeos 2017.10
laravel 5.4
Env: LINUX/MAC
Example:
PHP Version: 7.0
laravel 5.4
Env: LINUX/MAC
- decorator_delivery_DHL.jpg (113.38 KiB) Viewed 2214 times
- decorator_delivery.jpg (91.56 KiB) Viewed 2214 times
Re: decorators, delivery settings
Guess you have another delivery option for DE which is configured equivalently?
Your config seems to be OK, only the space character before "DE" in "country.delivery-exclude" of "POST AT" is incorrect.
Thanks for your answer but it finally does not work as you see in my screenshot, I've used a US address. Therefore I should only get the option DHL and others should be hidden.
- billing_delivery_adr.png (25.6 KiB) Viewed 2196 times
- screen_US_delivery.png (88.53 KiB) Viewed 2197 times
You haven't added the "Country" decorator to your Provider. Click at the "+" at the end of the provider input field and select "Country" so the decorator is added.
many thanks!
