Several Typoscript dosent work after last update
mantik
Post by mantik » 30 Nov 2017, 15:41
Somthings happpen after the update.
i have configuration that dosent works:
this one earlier works
plugin.tx_aimeos.settings.client.html.checkout.standard.address{
 billing{
                            mandatory {
                                1 = order.base.address.salutation
                                2 = order.base.address.firstname
                                3 = order.base.address.lastname
                                5 = order.base.address.address1
                                6 = order.base.address.postal
                                7 = order.base.address.city
                                9 = order.base.address.email
                            optional{
                                4 = order.base.address.company
                                8 = order.base.address.countryid
                        delivery{
                            mandatory {
                            optional{
                        countries{
                            0 = CH
                            1 = LI
This also dosent work never
config.language = de
config.sys_language_uid = 0
[globalVar = GP:L = 1]
    config.language = fr
    config.sys_language_uid = 1
[global]
[globalVar = GP:L = 2]
    config.language = it
    config.sys_language_uid = 2
[global]
In backendmodul on customer module i got a error: Fehler Invalid ISO language code "0"
This also does affect nothing - works earlier also not:
## Admin
module.tx_aimeos.settings.admin.jqadm {
    resource {
        dashboard {
            groups{
                0 = Shop
        site  {
            groups < module.tx_aimeos.settings.admin.jqadm.resource.dashboard.groups
        order  {
        customer  {
        catalog  {
i have all this settings in the setuzp.txt of my extension
When i login with a user of the usergroup "Shop" i got this exception:
Not allowed to access JQAdm "dashboard" client
Aimeos\Admin\JQAdm\Exception thrown in file
/var/www/vhosts/igtus.ch/httpdocs/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Factory.php in line 54.
Re: Several Typoscript dosent work after last update
Post by aimeos » 01 Dec 2017, 10:29
From which version do you updated? What is the installed version now?
There have been no changes in the stable 2017.x versions that can cause that to work any more:
 billing{
                            mandatory {
                            optional{
                        delivery{
                            mandatory {
                            optional{
                        countries{
                            0 = CH
                            1 = LI
mantik
Post by mantik » 01 Dec 2017, 12:37
aimeos wrote:From which version do you updated? What is the installed version now?
 billing{
                            mandatory {
                            optional{
                        delivery{
                            mandatory {
                            optional{
                        countries{
                            0 = CH
                            1 = LI
From this one of last moment to this of that moment.
In the last version there wasn't possible to ipload pdf's no works but this one dont works
Post by aimeos » 01 Dec 2017, 16:32
If you mean you've updated from 2017.10.0 to 2017.10.1: This was a minor bugfix release that didn't change anything that is releated to that. Here are the relevant commits:
- HTML client (last four commits): https://github.com/aimeos/ai-client-htm ... ts/2017.10
- TYPO3 integration (last three commits): https://github.com/aimeos/aimeos-typo3/commits/2017.10
It's more likely that you've changed something in your installation (maybe unintended)
mantik
Post by mantik » 04 Dec 2017, 14:07
aimeos wrote:If you mean you've updated from 2017.10.0 to 2017.10.1: This was a minor bugfix release that didn't change anything that is releated to that. Here are the relevant commits:
Ok then whats wrong that the typoscripts up dont work?
plugin.tx_aimeos.settings.client.html.checkout.standard{
                    adrress{
                        billing{
                            mandatory {
                            optional{
                        delivery{
                            mandatory {
                            optional{
                        countries{
                            0 = CH
                            1 = LI
Why all the fields and all countries apear?
Post by aimeos » 04 Dec 2017, 21:56
"adrress" is definitively spelled wrong, must be "address"
mantik
Post by mantik » 05 Dec 2017, 10:34
This was a hard punchline brooo!! Now it works :D.
Men it was correct. dont know why this changed...
thanx
