login as user from admin panel
antonlinderer
Post by antonlinderer » 13 Dec 2017, 10:04
Is there a way to login as another user from admin panel once you are logged in as administrator?
Re: login as user from admin panel
Post by aimeos » 13 Dec 2017, 23:15
No, you can't impersonate as another user. The Laravel users table and the Laravel Gate permission system isn't designed for that.
antonlinderer
Post by antonlinderer » 14 Dec 2017, 07:50
A popular boilerplate for Laravel has this feature of "Login As" User: http://laravel-boilerplate.com/5.5/docu ... ss-control
Post by aimeos » 15 Dec 2017, 08:40
It uses an alternative authorization package for permission handling. You can use that as well in your own application because it's based on the Laravel standard auth system. You only have to define an alternative gate function instead of using the Aimeos one: https://github.com/aimeos/aimeos-laravel#admin
hihaider196
Post by hihaider196 » 11 Jan 2019, 10:54
hi,
I want to remove signIn from admin portal and restrict changes in admin portal for any user(once product in inserted then you can't do anything).I need it as soon as possible. Help me
Thankyou
Post by aimeos » 11 Jan 2019, 11:04
If you want to limit the panels a user group is able to see, you can overwrite the configuration from the admin/jqadm/resource.php file: https://github.com/aimeos/ai-admin-jqad ... source.php
Add the settings to your ./config/shop.php in the "admin" section like:
'admin => [
    'jqadm' => [
        'resource' => [
            'order' => [
                'groups' => ['super', 'admin']
This example removes the order panel for all users with editor privileges.
hihaider196
Post by hihaider196 » 11 Jan 2019, 13:50
Can you please tell me the name of table, storing users information and also for admin and also how can i replace my phone number with email.
Thankyou
Post by aimeos » 14 Jan 2019, 13:19
All customer and administrator accounts are stored in the Laravel "users" table. Aimeos add a few more tables for delivery addresses (users_address), references to other domains (users_list) and arbitrary properties (users_property).
Post by aimeos » 09 Apr 2019, 19:14
You can manage the data of the users table in the Aimeos admin interface (customer panel) yourself
