Sorting Products in Backend
mantik
Re: Sorting Products in Backend
Post by mantik » 18 Dec 2017, 08:16
Hmmm no
i' ve configured module.tx_aimeos.settings.admin.jqadm for usergrops but even if i comment it out it changes anything.
nos3
Post by nos3 » 19 Dec 2017, 08:41
Please update the ai-customergroups extension. In the configuration, the "product" subpart was missing.
Sorry for that!
mantik
Post by mantik » 19 Dec 2017, 10:46
Yes!! that works.
mantik
Post by mantik » 21 Dec 2017, 08:56
just a question. if i change the order in the backend then nothing happen in frontend. but then after some time the order was correct.
Is there some kind of cache?
Post by aimeos » 21 Dec 2017, 09:01
After the index rebuild has been executed successfully, the product index contains the new positions too and therefore, the frontend shows the new order of the products.
mantik
Post by mantik » 21 Dec 2017, 11:02
How can the reindex be started?
Post by aimeos » 21 Dec 2017, 21:35
Run the Aimeos scheduler task that contains the "Index Rebuild" job. That will update the product index.
