Can't fetch attributes images at suggested products
Hi all!
I can't fetch images of atributes of suggested products.
I have suggested products at my client\html\templates\catalog\detail\body-default.php
At the suggested product I have the same code for including attributes like into the single product
Finally, at my attribute-custom.php I am recieving attribute's images.
But this code is working only at the single product. I can't fetch images of atributes of suggested products. What can I do?
<?php if( ( $posItems = $this->detailProductItem->getRefItems( 'product', null, 'suggestion' ) ) !== []
&& ( $products = $getProductList( $posItems, $this->get( 'detailProductItems', [] ) ) ) !== [] ) : ?>
<section class="catalog-detail-suggest">
<?= $this->partial(
$this->config( 'client/html/common/partials/products', 'common/partials/products-atpack.php' ),
array( 'products' => $products, 'itemprop' => 'isRelatedTo' )
</section>
<?php endif; ?>
<div class="items-attribute items-attribute<?=$productItem->getId();?>">
<?= $this->partial(
'common/partials/attribute-custom.php',
array(
'productItem' => $productItem,
'attributeItems' => $this->get( 'attributeItems', [] ),
'attributeConfigItems' => $productItem->getRefItems( 'attribute', null, 'config' ),
'attributeCustomItems' => $productItem->getRefItems( 'attribute', null, 'custom' ),
'attributeHiddenItems' => $productItem->getRefItems( 'attribute', null, 'hidden' ),
'subClass' => $productItem->getId()
</div>
<?php
foreach( $attribute->getListItems( 'media', 'default' ) as $listItem ) :
echo 'cool! I'm attribute's image!';
endforeach;
Re: Can't fetch attributes images at suggested products
In 2017.10, second level references (images of attributes fetched along with products) are not available automatically. This is the case since 2018.01. Before, you have to match with the items in "attributeItems", which contains those images.
