The each() function is deprecated. This message will be supp
I am preety new to Aimeos, i just hosted a demo site to test on line (heroku) i get this error when trying to view preetty much anything in the admin: (products, categories, customer, order..etc) on the expert admin.
The each() function is deprecated. This message will be suppressed on further calls
It doesn't happen on my local
Please Help.
Please Help.
- Screen Shot 2018-02-14 at 06.31.24.png (145.28 KiB) Viewed 1870 times
Re: The each() function is deprecated. This message will be
Which PHP version are you using?
each() is deprecated in PHP 7.2 and we backported the necessary change to the Aimeos core 2017.10. If you run "composer update" it should be working on your server too.
Thank you very much. This solved my problem.
Cheers
Cheers
