Creating product in Aimeos
Hi there,
want to scrape the products from this site into Aimeos ,
https://www.supply-only.co.uk/index.php ... &cPath=310
example product
https://www.supply-only.co.uk/index.php ... ct_id=3269
could you run us through for the 1 product with its options and sizes if you click on the green NEXT button each time you will see , whats the best way of entering into Aimeos which parts and fields ? because it has many options with images it will really help if you can guide us please.
Thank you so much
example product
Thank you so much
Re: Creating product in Aimeos
As these products can contain many options, a selection product with variants wouldn't be suitable because this would lead to arount 920 million variants. Instead, use an article with the required number of options for each option type and two custom attributes for width and height so customers can enter custom values. For the image, you will have to implement some kind of multi image overlay because you can't add an image for each combination of options.
