Multiple Sites
Multiple Sites
I created an second site.
https://aimeos.org/docs/User_Manual/Adm ... with_sites
My Problem is that i cant see the site changer in normal modus.
In the expert modus i see the site changer and can use it but in normal modus i am unable to select my second site.
What can i do to see the site changer in normal modus? Thanks.
Typo3 7.6.x / Aimeos 17.10.0
- How it is on expert modus
- Expert Modus.JPG (15.34 KiB) Viewed 1715 times
- How it is on normal modus
- Normal Modus.JPG (16.17 KiB) Viewed 1715 times
- How it should be on normal modus
- 800px-Admin-concepts-sites-selector.png (22.16 KiB) Viewed 1715 times
Re: Multiple Sites
In 2017.10 you can't change between all sites in the simple admin interface because your user only has rights for one site. In the latest dev-master branch it's possible to change between all sites if your user has super user privileges.
Re: Multiple Sites
I installed now aimeos 18.1.1 and like before i cannot switch between multiple sites...
Re: Multiple Sites
There was a bug in the page template that renders the sidebar:
https://github.com/aimeos/ai-admin-jqad ... 0e78fcdeec
The fix will be included in the upcoming 18.4.0 release.
