Change starting order ID
If I wanted to change the initial order ID, to 1000 instead of 1, can I simply run the query below? Or will that break something/everything?
ALTER TABLE mshop_order AUTO_INCREMENT = 1000;
Re: Change starting order ID
No problem at all
