Coupon related to a product?
I want to use the coupons-option , but where can I link a product to coupon-code?
And: every coupon-code should be only used once by a Account/email - which code I use?
Thank you
Thank you
Re: Coupon related to a product?
There are two decorators you can apply to a coupon provider in the admin panel ("+" symbol in detail view):
Require a specific product:
https://github.com/aimeos/aimeos-core/b ... quired.php
Allow coupon once per customer e-mail:
https://github.com/aimeos/aimeos-core/b ... r/Once.php
Thanks,
but is there no interface-option in the Aimeos-backend to link a product to a coupon-key?
The "Required" decorator allows you to specify a product that must be in the basket of the customer so the coupon is valid: https://aimeos.org/docs/User_Manual/Adm ... s#Required
The other way round (configure in the product panel that this product belongs to a coupon) isn't possible.
Does this answer your question or is there a misunderstanding? What do you want to achieve?
Yes, i can use required.productcode, but I have so much products to insert manually ... there is no code for alle products?
for example: required.productcode = all ?
It's not necessary to configure that at least one product is necessary. This is the default.
You can configure a minium basket value if you want: https://aimeos.org/docs/User_Manual/Adm ... sketValues
When I use for example the demo Coupon ( "demo-rebate" ,see image 2) I get the error "No product with code "demo-rebate" found" (see image 1).
- percent2.png (41.29 KiB) Viewed 4017 times
- percent1.png (24.51 KiB) Viewed 4017 times
The FixedRebate and PercentRebate coupon providers need a product that will be added to the basket when the coupon is applied. This product will then show up in the basket and a negative price is added to that product in the basket by the providers.
You've deleted the demo rebate product (code: "demo-rebate") so you get the error from your screenshot. Add a new rebate product (normal article not associated to a category) and use its code in the coupon configuration. Then, it will work again.
Now I understand.
Thank you !
Thank you !
is it possible to show the used coupon-code in the customer Email?
