Laravel 5.5 Aimeos e-commerce install issue in ubuntu
I installed laravel 5.5 aimeos e-commerce and logged into admin side, but it is showing only a blank dashboard. There is no error message appearing. What could be the reason?. Can any one help me out of this issue. I am attaching the screenshot with this.
- This is how that page is appearing.
- Screenshot-2018-4-5 Laravel.png (11.84 KiB) Viewed 2346 times
Re: Laravel 5.5 Aimeos e-commerce install issue in ubuntu
Hello Geethu,
I installed it yesterday on Ubuntu 16.04 and had no problems. Are you able to see the marketplace once you run artisan serve? If so, the url should look like this: http://127.0.0.1:8000/list , just replace list to admin: http://127.0.0.1:8000/admin
Enter your credentials and it should now show the admin panel.
I installed aimeos marketplace it using composer and after I set up the database as shown in this link: https://github.com/aimeos/aimeos
Regards,
Jorge
Regards,
Jorge
Hello Jorge
Thanks for your reply. Front end is working fine but I am not getting the back end. Anyway I am going to install it again from start. I hope it will work this time. If not what may be the issue?.
Regards,
Geethu
Regards,
Geethu
The admin interface should be available here: http://127.0.0.1:8000/admin
I have install aimeos, front end is working fine but back-end is not showing.
FRONT end url: http://127.0.0.1:8000/list Working fine but back end not working
Back end url: http://127.0.0.1:8000/admin this is redirect to http://127.0.0.1:8000/home and showing dashboard blank page.
Please help
Please help
Please make sure you have installed at least Aimeos 2018.07.3 for Laravel. The versions before had a bug for non-superuser accounts that prevents showing the Aimeos admin interface.
