How to add additional fields to a customer
mohal_04
Re: How to add additional fields to a customer
Post by mohal_04 » 11 Apr 2018, 12:18
aimeos wrote:You can find documentation about Vue.JS there: https://vuejs.org/
You don't need that much knowledge about Vue.JS. There are only three important things:
1.) Add the new key in your new template there:
https://github.com/aimeos/ai-admin-jqad ... rd.php#L11
2.) Copy the form line and replace "price.value" by your new key:
https://github.com/aimeos/ai-admin-jqad ... rd.php#L70
3.) Check if your new key/value is listed there (use the web inspector for example):
https://github.com/aimeos/ai-admin-jqad ... rd.php#L23
So, what to do if point 3 fails? Where does "data-items=" get populated?
Thanks!
tenkraD
Post by tenkraD » 11 Apr 2018, 23:17
aimeos wrote:Your new value isn't set in the item there:
https://github.com/aimeos/ai-admin-jqad ... d.php#L357
-you have to add youre setter from item class there in fromArray "setMinimumAdvertisedPrice($this->getValue( $data, 'price.minimumadvertisedprice' . $idx, ' 0.00' ))" . This is where the data is populated.
and that this new file instead of the standard is recognized u have to add this configuration value
*thanks to nos3 user* https://aimeos.org/docs/Configuration/C ... price/name
See Extend Stock ==> post6012.html#p6012
bye tenkraD
tenkraD
Post by tenkraD » 11 Apr 2018, 23:27
bye tenkraD
Post by aimeos » 12 Apr 2018, 07:14
All modifications must be done in your own extension. Never change the Aimeos Core!
If you need to store additional data from the admin interface, you have to extend the existing class using a new name, overwrite the fromArray() method and configure your new class name like @tenkraD said.
The data for the template is populated there:
https://github.com/aimeos/ai-admin-jqad ... d.php#L420
mohal_04
Post by mohal_04 » 12 Apr 2018, 07:54
aimeos wrote:All modifications must be done in your own extension. Never change the Aimeos Core!
But I have to make changes in Standard.php file, otherwise, value of new field is not being saved.
Standard.php is in this directory:
./ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Product/Price/Standard.php
The fromArray() method of my extension (see below) doesn't save data.
./ext/10buckonly/lib/custom/src/MShop/Price/Manager/Custompricefields.php
public function fromArray(array $list)
        $unknown = [];
        $list = parent::fromArray($list);
        foreach ($list as $key => $value) {
            switch ($key) {
                case 'price.minimumadvertisedprice':
                    $this->setMinimumAdvertisedPrice($value);
                    break;
                case 'price.productioncost':
                    $this->setProductioncost($value);
                    break;
                default:
                    $unknown[$key] = $value;
        return $unknown;
This thing has made me pull my hairs out.
Thanks!
Post by aimeos » 12 Apr 2018, 08:03
No, it's the same as for the managers: You have to extend from the standard class and create e.g.
./ext/myextendsion/admin/jqadm/src/Admin/JQAdm/Product/Price/Mystandard.php
which contains:
class MyStandard extends Standard
    protected function fromArray( \Aimeos\MShop\Product\Item\Iface $item, array $data )
        // your modified code
and configure your new class using:
admin/jqadm/product/price/name = Mystandard
e.g. for Laravel in config/shop.php:
'admin' => [
    'jqadm' => [
        'product' => [
            'price' => [
                'name' => 'Mystandard'
tenkraD
Post by tenkraD » 12 Apr 2018, 08:04
No not here "./ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Product/Price/Standard.php"
See Extend Stock for a full working example ==> post6012.html#p6012
This should solve your problem. I done the same but with Stock Class instead of Price.
bye tenkraD
mohal_04
Post by mohal_04 » 12 Apr 2018, 08:19
The only way for me to save value of my new field is to add following two statements in fromArray() method of Standard class.
$priceItem->setMinimumadvertisedprice( $this->getValue( $data, 'price.minimumadvertisedprice/' . $idx, '0.00' ) );
$priceItem->setProductioncost( $this->getValue( $data, 'price.productioncost/' . $idx, '0.00' ) );
The fromArray() method in my extension is not saving value. :'( :'( :'( :'( :'(
Thanks!
tenkraD
Post by tenkraD » 12 Apr 2018, 08:47
C'mon mohal,
mohal_04
Post by mohal_04 » 12 Apr 2018, 09:35
tenkraD wrote:C'mon mohal,
Thanks a lot buddy!!! Issue resolved!!! Blood Pressure dropping now!!! I hope this is the last complex issue that I faced. Thanks A LOT!!!
Thanks!
