Laravel - Extend Vue.js in Custom Extension
mohal_04
Post by mohal_04 » 13 Apr 2018, 06:35
Hello again,
So, I was making few changes in Stock Section of Product Edit form. So, I have added another field for stock.
And want to sum up both stocks using JavaScript. So, I added some code in Vue.js file, i.e. product.js file inside themes directory. Here is the complete path:
./ext/ai-admin-jqadm/admin/jqadm/themes/product.js
It is working fine but I think as it is a custom code, therefore, I should put it under my extension like the path below:
./ext/myextension/admin/jqadm/themes/product.js
But when I do it, the sum up functionality doesn't work. Below is my modified product.js file code, which I added:
Aimeos.Product.Stock = {
	init : function()  {
		this.vstock = new Vue({
			'el': '.item-stock .stock-list',
			'data': {
				'items': $(".item-stock .stock-list").data("items"),
				'keys': $(".item-stock .stock-list").data("keys"),
				'prefix': $(".item-stock .stock-list").data("prefix"),
				'siteid': $(".item-stock .stock-list").data("siteid"),
				'numtypes': $(".item-stock .stock-list").data("numtypes")
			methods: {
				checkSite : function(key, idx) {
					return this.items[key][idx] != this.siteid;
				totalStock : function() {
					var totalStock = 0;
					for(var key in this.items['stock.stocklevel']) {
						if(!isNaN(parseInt(this.items['stock.stocklevel'][key])))
							totalStock += parseInt(this.items['stock.stocklevel'][key]);
						console.log(totalStock);
					$('.item-stocktotal').val(totalStock);
				addItem : function() {
					var idx = (this.items[this.prefix + 'id'] || []).length;
					for(var key in this.keys) {
						key = this.keys[key]; this.$set(this.items, key, (this.items[key] || []).concat(['']));
					this.$set(this.items[this.prefix + 'siteid'], idx, this.siteid);
					this.numtypes--;
				removeItem : function(idx) {
					for(key in this.items) {
						this.items[key].splice(idx, 1);
					this.numtypes++;
		this.vstock.totalStock()
totalStock is the function that I added. Can anyone guide me how to extend Vue.js files?
Thanks!
peter69
Re: Laravel - Extend Vue.js in Custom Extension
Post by peter69 » 11 Nov 2022, 21:37
I think the only way to do it is to contribute to ai-admin-jqadm: https://github.com/aimeos/ai-admin-jqadm
Post by aimeos » 12 Nov 2022, 05:30
You can overwrite anything in Aimeos besides PHP base classes :-)
Just put your JS code in the ./ext/myextension/themes/admin/jqadm/custom.js:
https://aimeos.org/docs/latest/admin/jqadm/customize/
peter69
Post by peter69 » 12 Nov 2022, 05:56
I will try!
Thank you!
