sitemap product url
27bit.ru
Re: sitemap product url
Post by 27bit.ru » 26 Apr 2017, 13:42
aimeos wrote:URLs in sitemaps are escaped (& -> &) which you have to revert first before you can open the URL in your browser:
http://new.site.ru?id=13&ai%5Bcontrolle ... rodid%5D=1
Thank you. It seems that everything works.
JonasEberleDmind
Post by JonasEberleDmind » 26 Apr 2018, 12:03
I am struggling to get realurl-URLs in the sitemap. (Typo3 7.6.27, realurl 2.2.1)
In https://www.interfahnen.com/aimeos-sitemap-1.xml.gz they are "un-realurled" and look like this:
https://www.interfahnen.com/?id=210&ai% ... id%5D=1244
Is it even possible to get realurled URLs in a scheduler Task context? Anybody got that working?
Post by aimeos » 27 Apr 2018, 10:42
Which version of Aimeos TYPO3 extension are you using?
