Invalid response when updating things in admin view
I have this error that appears when I try to edit or delete entries in the admin view:
It can be noted that the actions is still done (I.E.: The product is removed), I just have to go back and reload the page
I run Aimeos 2018.04 latest non-dev with symfony 2.8 in production with apache 2.4, php 5.6.35 via Wampserver (windows).
The controller must return a response (Object(Aimeos\MW\View\Helper\Response\Symfony2) given).
500 Internal Server Error - LogicException
Re: Invalid response when updating things in admin view
Can you please execute "composer update" again? You should get "aimeos/ai-admin-jqadm" version 2018.04.9 which fixes the problem.
Sadly upgrading didn't correct the problem in my app.
here's my composer.json:
also a picture of the installed packages is attached to this reply
"name": "symfony/framework-standard-edition",
"description": "The \"Symfony Standard Edition\" distribution",
"autoload": {
"psr-0": { "": "src/" }
"require": {
"php": ">=5.6.31",
"symfony/symfony": "2.8.*",
"doctrine/orm": "~2.2,>=2.2.3",
"doctrine/doctrine-bundle": "~1.4,>=1.4.0",
"twig/extensions": ">=1.5.0",
"symfony/assetic-bundle": "~2.3,>=2.3.0",
"symfony/swiftmailer-bundle": "~2.3,>=2.3.0",
"jms/security-extra-bundle": "~1.6,>=1.6.0",
"jms/di-extra-bundle": "~1.4",
"jms/payment-core-bundle": "1.1.0",
"jms/payment-paypal-bundle": "1.0.0",
"twbs/bootstrap": "~3.3,>=3.3.7",
"sensio/framework-extra-bundle": "~2.3",
"stof/doctrine-extensions-bundle": ">=1.2",
"friendsofsymfony/user-bundle": ">=1.3.7",
"orderly/paypal-ipn-bundle": "dev-master",
"egulias/email-validator": "~1.2",
"symfony/monolog-bundle": "~2.4",
"aimeos/aimeos-symfony": "~2018.04@dev"
"require-dev": {
"sensio/distribution-bundle": "~2.2,>=2.2.0",
"doctrine/doctrine-fixtures-bundle": ">=2.3.0",
"sensio/generator-bundle": "~2.2,>=2.2.0"
"scripts": {
"post-install-cmd": [
"Aimeos\\ShopBundle\\Composer\\ScriptHandler::installBundle",
"Aimeos\\ShopBundle\\Composer\\ScriptHandler::updateConfig",
"Aimeos\\ShopBundle\\Composer\\ScriptHandler::setupDatabase",
"Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::buildBootstrap",
"Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::clearCache",
"Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::installAssets",
"Sensio\\Bundle\\DistributionBundle\\Composer\\ScriptHandler::installRequirementsFile"
"post-update-cmd": [
"config": {
"bin-dir": "bin"
"extra": {
"symfony-app-dir": "app",
"symfony-bin-dir": "app",
"symfony-var-dir": "var",
"symfony-web-dir": "web"
- The error page
- Capture2.PNG (53.79 KiB) Viewed 5928 times
- Capture.PNG (7.03 KiB) Viewed 5928 times
Can you try to add the Symfony PSR-7 bridge?
http://symfony.com/doc/current/components/psr7.html
Resp. can you post the output of "composer show"?
FInally, I opted to separate the shop from the main wweb site, now the shop runs on symfony 3 and it works perfectly. I'll see to show you the result of what you asked, but it'll have to wait, sorry.
