How can I run by entering only domain.name without :8000
How can I run by entering only domain.name without poing port number 8000 (not like this: domain.name:8000)?
Re: How can I run by entering only domain.name without :8000
That's only necessary for local testing. On a web server the standard ports 80 or 443 are used.
Ok, got it. But I work with it on my local machine only with pointing port number (localhost:8000) because without this it does not work. Now I move to hostgator server and cant start it at all. If I trying to start it without port number it returns me 503 error. What I need setup additionally for making it work on server and without 8000?
If will be correct what is the procedure of starting without pointing 8000 port after proper installing?
