Unic order ID
Alex K
Unic order ID
Post by Alex K » 01 Jun 2018, 10:41
Hi! I have two shops on aimeos and i have situation, when i got same orders ID on my email. So how can change order ID like this: FR1-FRNNN. I just want to add Letters to begining of Order ID.
Thank you!
Re: Unic order ID
Post by aimeos » 01 Jun 2018, 20:54
The order IDs are auto_incement values from MySQL so you can only add prefixes when e.g. the e-mail is sent to you.
Alex K
Re: Unic order ID
Post by Alex K » 02 Jun 2018, 14:12
OK, i see. To add prefix to email i need to change email template or theris any config for this?
Re: Unic order ID
Post by aimeos » 02 Jun 2018, 20:29
Yes, copy the e-mail template to your own extension and modify the line where it outputs the order ID
