baket empty after login / logout due to new sessionID
merzilla
Post by merzilla » 08 Jun 2018, 17:27
Currently on TYPO3 8.7.15, but maybe since 8.7.11, the basket get emptied after a fe login (or logout).
The session cookie "fe_typo_user" remains, but you can see that the value gets a new session ID.
Benni Mack already noticed that the cookie handling did not change in the TYPO3 core, but what about sessions?
Can this be fixed and do you already know until when?
Thank you and regards,
Ralf
Re: baket empty after login / logout due to new sessionID
Post by aimeos » 12 Jun 2018, 12:07
We've tried with different TYPO3 8.7.x versions (.13 and .16 specifically) but none of those versions lost the session data after login or logout. What's true is that the session cookie value changes but that had no effect on the session content.
Do you have different settings for SYS/session in your LocalConfiguration.php file?
merzilla
Post by merzilla » 12 Jun 2018, 17:33
I could not find out what's different yet. We use the default configuration for the sessionBackend.
'FE' => [
                'backend' => \TYPO3\CMS\Core\Session\Backend\DatabaseSessionBackend::class,
                'options' => [
                    'table' => 'fe_sessions',
                    'has_anonymous' => true,
"fe_session" gets a new entry on login.
Do you have any hint? Anyways I´ll keep on searching...
Cheers
merzilla
