No images are displaying in products
in configured a product, but i can not see the images in the webshop.
Shop url: http://localhost:8888/typo3/
http://localhost:8888/uploads/tx_aimeos ... bf8c76.jpg
I add 'typo3' to the url, then i see the picture.
http://localhost:8888/typo3/uploads/tx_ ... bf8c76.jpg
Aimeos web shop: 18.4.2
Aimeos web shop distribution: 18.4.0
Typo3: 8.7.16
Has anyone an idea?
Best regards
Helmut
Typo3: 8.7.16
Has anyone an idea?
Best regards
Helmut
- typo3.JPG (93.86 KiB) Viewed 1260 times
Re: No images are displaying in products
Select your root page and go to the "Template" panel. In the constants edior, you can choose "Aimeos web shop: Advanced" and enter the base path to the images directory ("/typo3/uploads/tx_aimeos" in your case).
Alternatively, you can set the base path in your TypoScript setup section by hand:
plugin.tx_aimeos.settings.client.html.common.content.baseurl = /typo3/uploads/tx_aimeos
