Catalog (Category) Import via Script
mohal_04
Post by mohal_04 » 28 Jun 2018, 12:15
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.1.18
Hi guys,
I need to import product categories from old website into this new Laravel Aimeos setup. So, can you guide me how to do it using a PHP Script. Or is there any Laravel (Aimeos) Package that could help me?
In "mshop_catalog" table, I see all catalog items (categories). I can write a PHP script that will insert new categories in this table but I noticed that "mshop_catalog" table is using Nested Set Model, which is something new for me. So, can you help me understand, how I write a script that help me with adjusting Nested Set Model also.
Thanks!
Re: Catalog (Category) Import via Script
Post by aimeos » 29 Jun 2018, 10:54
You can use the catalog CSV importer if you can export your old categories in that format:
https://aimeos.org/docs/Developers/Cont ... g_from_CSV
The alternative is to create a job controller that uses the catalog manager to import an arbitrary format:
- https://aimeos.org/docs/Developers/Cont ... controller
- https://aimeos.org/api/latest/class-Aim ... ndard.html
mohal_04
Post by mohal_04 » 29 Jun 2018, 11:55
aimeos wrote:You can use the catalog CSV importer if you can export your old categories in that format:
Thanks for the help. I shall look into both of these solutions. Do we have similar solutions for Products, Customers, and Orders?
Please, reply!
Thanks!
Post by aimeos » 29 Jun 2018, 19:21
For products, there's a CSV importer too. If you want to migrate from an existing foreign system (Magento, whatever), then the best way is to write setup tasks for migrating the data if you have access to both databases simultaniously: https://aimeos.org/docs/Developers/Library/Setup_tasks
There you have the possibility to use the Aimeos managers to migrate complex data like the category tree ($this->additional is the context item) but also have to possibility to use hand written SQL statements where needed.
mohal_04
Post by mohal_04 » 02 Jul 2018, 07:43
I have placed CSV file in "./public/csv" directory and changed configuration in "./config/shop.php" file like this:
'controller' => [
	    'jobs' => array(
	        'catalog' => array(
	            'import' => array(
	                'csv' => array(
	                    'location' => 'public/csv/catalog.csv'
Now, how can I run this import? I am doing this in Laravel 5.6. Please help!
Thanks!
Post by aimeos » 02 Jul 2018, 08:26
Execute the "catalog/import/csv" job: https://aimeos.org/docs/Laravel/Configure_cronjobs
Your location has to be a directory by default as long as you don't configure this otherwise.
mohal_04
Post by mohal_04 » 03 Jul 2018, 10:09
aimeos wrote:Execute the "catalog/import/csv" job: https://aimeos.org/docs/Laravel/Configure_cronjobs
Thank you very much for your help! I successfully imported Categories. Now the next difficult task is to import products. Any helpful material on that?
Thanks!
Post by aimeos » 03 Jul 2018, 10:33
mohal_04
Post by mohal_04 » 04 Jul 2018, 08:02
I have very different data in JSON format. Is there any alternative method of importing product data? I want to conditionally import catalog code.
Thanks!
Post by aimeos » 05 Jul 2018, 15:59
Like said, create a job controller that uses the managers to import an arbitrary format directly:
- https://aimeos.org/api/latest/namespace ... MShop.html
